Finally got the tunes close on the new triple setup . Took it to Friday Night Drags at Texas Motorspeed Way . No times just arm drop but they did clock it at 110 MPH at the finish line . Problem is for the 2nd time, 2nd converter it took out the bearing in the converter . Same symptoms as the first one. Nice run on the 1st run but the truck never left right on the next run and trans got hot . When it shows that does the ECM pull the power ? Cause that is what it felt like big time . This run was against a Toyota SBC on slicks. The Goerend LL has tuning hits on it and 4-5 track runs on it . It's lifetime warranty so I'm pulling it and sending it back for warranty.for clarification the 1st converter was a precision that was tug welded and had a Goerend billet stator added to it by my local converter shop . It would only brake stall to 2200 or so . When I had it checked the bearings were gone in it but easily fixed. Took the opportunity to go to the Goerend LL with more stall . So what to do to keep a converter in it ? Any suggestions . Leave with less boost off the line ? With Precision at 2200 I was at 15# and with Goerend at 3100 I was at 30--40#.https://www.facebook.com/jeremy.clark.7792/posts/10209016384719610
