IMHO I wouldn't ever go high compression on a modded duramax. IMHO i think this is why alot of aftermarket rods/parts have been failing is becuase of this. Good luck keeping it together with that much air and high c/p. Just remember, If it were such a good idea to go up in c/r all the tractor pullers/ turboed car guys would be doing it too:thumb: I wouldn't go any higher than what you were going to go for before.
Can't compare with tractor pullers. Those guys run 150 psi+ and higher rpms. The guy wants to use the truck for street too. I would stay 16.5:1 cr. If I was going all out, and did just pulling and dragracing, then I would lower the cr. Otherwise you will have a slow spoooling, laggy pig for street duty. Think of what you really want and go with it:thumb:
