This is all at the tire.
Running big pulse width increases cyl pressure but also adds a ton of undue heat to the piston and makes it very hard to cool back down before the next cycle. Just like heating a piece of steel up over and over, it becomes brittle in the weak areas.
So if you have already started to hurt the pistons, adding bigger injectors to bring pulse width down won’t really save you because we don’t know how far gone the pistons are.
None of this is “the Bible” because you will have those that challenge the norm.
I’ve wanted to take a stock lb7 bottom end, throw some high flowing heads on, nice cam, big single, big injectors in and spin the thing to 5500rpm to see what kind of power it could make and what it could take. That would be low torque but high hp. Drop it in a light car or truck and it would be fun. Hell I’d even mod some thing to just put l5p heads on it to keep cost lower assuming heavy valve springs from older years works. This obviously with all the extra money I have laying around
I know it could break with less, or be a freak of nature. I had heard about the cylinder pressure being an issue, didn't think of the heat cycling
