looking for a mechanical rail pressure gauge. my boost and pyro are Ultra Light II's so i would like to find that same gauge for rail pressure. Also im assuming a 0-15psi fuel pressure gauge is plenty right? Thanks
.trying to get 20-27k psi of fuel into the cab would be a nightmare and extremely dangerous.
there's a little deal that goes where the filter bleeder screw is and it reads from there.
Mechant Auto sells the little adapter fitting that goes onto the bleed screw and adapts it to a 1/8" pipe wich is what the little transducer that comes with the fuel pressure gauge when you buy it. If you shop around a bit, you can find a good deal on the gauges. I think I used amazon when I bought mine. List was 225ish and I found it for 175. Im looking for a rail pressure gauge to match my autometer ultralites as well. As far as I know, it taps into the rail pressure sensor and transmits the elctronic signal. I know Im not plumbing 27K of fuel pressure into the cab :thumb:
Link to the fitting adapter: http://www.merchant-automotive.com/fuelpressuregaugeadapter.aspx
And I have a 15psi fuel pressure gauge. My AD 1 puts out about 10-12 psi
the site says the fuel pressure gauge needs to be mounted outside the vehicle? f*ck that
