Well I guess it's time
paint94979
Beer Nazi
Sep 18, 2006
11,715
Brian Brian Brian... You need drag radials or cheater slicks. Also get that damn converter out of your transmission that "expert" who advised you to go that route should be kicked in the head lol. What psi are you launching at? Truck hopping? Spinning? You aren't still running a single cp3 are you?
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
X2 on the slicks or drag radials with a big single your gonna absolutely need some sticky meats.Oh yeah and get that dam t/c out of there didn't you have a deal made with Ruben?
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
or you could just fix your IC that is split open, its a long shot but a boost leak might have something with a turbo that has an open AR not make the boost it should :rolleyes:
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
what converter is in there?
58
Not the one that it needs.
If it's the converter then why does the same one work fine in my truck with almost the same turbo and smaller injectors? It can get 10 psi in 5-6 seconds and can get more when the brakes are warm.
Are you flat footing it then slowly backing off or trying to do the Cummins Creep?
Dirtymaxx03
3,109
58
What exhaust housing are you running Chris?
gmduramax
Shits broke
Jun 12, 2008
4,082
252
Nor cal
58
10psi in 5-6 seconds :baby:
I can hit 30 in 5 seconds with a proper converter.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
This is how long it took to get to 15psi.
1500Us, max of 4-7* of timing in spool area's. max of 19* at WOT
[YOUTUBE]iRpP3yRW4y4[/YOUTUBE]
