Welded front diff
RobsDmax
832
Arthur, Ontario
Maybe someone needs to take me to school! I don't see a single negative, only benefits. Who drives in a parking lot getting groceries with it in 4x4 anyways
I see that it would be wicked for pulling, which is what i use my truck for in the summer. But it is also my winter ride, and sometimes I have to turn while in 4x4, because not all roads are straight, so if you cant turn with it welded, it is less than useful to me.
5,985
take an icy corner in 4wd with the front end locked up and the rear end locked up. the front end will push like an MF'er cause the tires can not turn different speeds and you have no slip in the t-case to let the front and rear driveshafts to turn different speeds so the give HAS to be at the tires or what ever breaks along the way to allow that difference in speed. once one of those front tires breaks loose (or both which is very likely due to the spooled front now) and you have any momentum behind you, your gunna be going straight. its hard enough on just a little slope thats iced over to keep traction in a tight turn with 4wd locked in and an open front. its the same reason i can turn corners sooooo much better when i pop my zuk out of 4lo into 2lo as the locker will not be loaded up so it will unlock and i can turn sharper regardless of my spooled rear. then there is using the truck in 4lo to back up trailers from the street to the house and so on. its the little things you dont think about on a DD where it can cause a bit of pain in the ass.
then as i say before, the front driveshaft will turn all the time now which can be an issue for true lifted trucks
1pieceatatime
179
Schuyler NY
Wait I can just weld my front diff instead of spending 750 on a elocker, no way???? What happens if you need to use 4x4 in the winter???
Kind of entertaining that these guys who's states shut down over an inch of snow don't see the downside to the lincoln locker in a daily driver........
