I installed an EGR blocker plate and now I am noticing coolant issues. First thing I saw was my upper radiator hose was collapsed. From what ive read that's just a bad coolant cap. Now I noticed a small coolant leak from sitting overnight. Checked the upper radiator hose in the morning before starting the truck and it was hard (Head Gasket), and also coolant reservoir was low. My temp does not fluctuate and I have hot heat. I topped off the coolant and continued to drive with no issues. Checked the upper radiator hose again the next morning and it was fine. Symptoms are come and go. There is pressure in the coolant tank as well. I did not reroute the coolant after blocking the EGR. Looks like coolant is possibly leaking from a hose that goes into the firewall, but leaking from the front of the motor. Any ideas on the issue before I dump time and money into anything?? I have a hard time believing its a HG but still concerned about the issue.
