Weight Box???
Team Overkill
<---Where my money goes
Oct 15, 2009
82
Illinois/Nebraska
Hey guys! Hoping someone can post up some pics of their weight box. Looking for some ideas for mounting it to the frame and wondering what would be strong enough to hold the box up without bending. Thanks!
Operator1
477
NC
I have 3" x 3" x 1/4 wall tubing. Bolts into the tow hook bolt holes. Lots of guys around here weld receiver tubes in the frame and build brackets from 2" tubing. How much weight are you putting up front?
THEREDDEVIL
A Bad seed
Jul 28, 2010
512
Godfrey, il
Here's mine. 2x2 solid stock has had 1000lbs on it.
06dmax
Aug 5, 2009
295
i hooked mine up to my western ultra mount plow mounts they bolt right to the bottom of the frame and held 1200 pounds off the front only pull with 800 but had to test it hasnt bent yet
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I'd suggest using a bottle jack under the weights while trailering it. Thats when they bend mostly. .5x4 flatbar is twisted pretty good now from bouncing up and down on the trailer with 1400#
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
39
One time last year I had 25 100lb plates on my old rack plus me and my friend both stood and bounced on it to make sure it didnt fall off when i went down the track and it didnt budge. It was 3x3 notched to fit under the crossmember.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Mine is notched too. It bent the pipe crossmember alittle bit hauling it one night on a rough road. Very dumb, full 1400 weights on the bracket, truck bounced on the trailer, wasnt tied down by weight rack just the a arms, pintle hitch, empty dumptruck. About the worse riding haul I've ever been on. Since then since its weaker and weaker every pull and i have to keep adding shims to the to top side of where I notched out to go under the crossmember. I'm thinking 2 1/8 would work fine, just heat up the crossmember and slug it in there with a hammer. I just dont think I could find 2 1/8 od tube. 2 in would be kinda "rigged" in there but I guess it would still be tight. I could drill and tap the bottom of the rack to use the factory bolt holes in the frame for the bottom bolt of the tow hooks. Right now its just pinned in the side holes.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Some pics.
Sent from my PC36100 using Tapatalk 2
Harbin_22
3,858
7
Southern Indiana
I cut out some pieces of angle iron that go on before the bolts go in. Kinda hard to explain but it is about 8" long and helps support the frame where the bolts go in
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I was thinking the same. Angle would work better but I was just gonna use flat bar. Kinda like a big washer for the lower bolts.
Sledheadxp800r
Dec 13, 2010
1,151
39
It was also not just pinned in. It was bolted from through the frame in the front and the rear was also bolted up from the bottom.
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
Mine was notched to slide in like everyone else has said. We blocked it up on the trailer but bent the tube slightly on a test launch.:roflmao: I also drilled a second hole in the frame behind the main holes for the tow hooks so it would actually hold the weight rather than it resting against that tube. Not sure if it is the best way but it worked and held about 1600 lbs without issue.
duramaxsandwich
Mar 30, 2009
206
if you put round tubing inside the square tubing it will help. make sure you have a jack or something under the weight bar going down the road on the trailer.
