Weigh Station question
Cougar281
1,809
253
St Louis, MO
I know there are some here that haul commercially and are likely familiar with weigh stations. My understanding of them is that they are meant for commercial drivers hauling for commerce or other commercial reasons, and that if you're running personal, you don't need to go through them. I made multiple trips back when I had my 45' 5th wheel, never went through them or had any issues, and about two months ago made a trip from NY to MO with a U-Haul 26' straight truck and a 6x12 trailer loaded up with the first round of my families belongings as they're moving to MO, and didn't have any issues.
I'm going to be making another trip with another 26' truck, but this time, it's not going to be U-Haul because they couldn't get a 26' truck and the U-Haul was quite a bit more expensive than this one (and this one is a BRAND NEW International Diesel with 1500 miles on it - the U-Haul we had had a 8.1L Gas that coudln't get out of its own way).
As far as I know, Budget, Ryder and Enterprise all rent to both people moving, such as this, and to commercial drivers, such as if their truck is out of commission, whereas U-Haul is 'intended' for personal rentals only, so it's less 'clear cut' that we are not running commercially.
So do I have to go through weigh stations? Should I? If I didn't and they come after me, will they cite me, or when it's determined that I'm not running commercial we're sent on our way? If I go through any stations that are open (The two along the route I passed on I-70 in Indiana and Illinois were both closed last Sunday - I don't know about any along I-80 from NY to I-76/I-71 in Ohio), is there any reason they shouldn't follow me through (My mother and sister will be following me in my sisters van) so that we don't get split up and they don't have to pull over on the side of the interstate or creep along like slugs while I try to catch up? Really, as long as the truck isn't overweight (26,000 GVW), going through weigh stations should be a non-issue.
Maybe we'll get lucky and they'll all be closed, being as we'll be traveling on Sunday.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I’ve never in my life stopped at a weigh station. My dad always told me “they have those flashing lights for a reason, they’ll come get you if it’s important”
Just hammer down. You don’t need to stop. And I’m the rare case they do come get you play dumb. because honestly you don’t know if you’re supposed to stop or not.
I view weigh stations as commercial only, until they come get me and make me come back I’ll be passing everyone of them with a clean conscious
Blackmax123
683
central Pennsylvania
I think it's really depending on state.
A DOT office did a presentation where I work on load securment. The weigh station question was brought up and he stated if your driving a loaded truck or hauling a trailer you needed to pull in. But he said in most cases they'll just wave pickups through u less something catches their eye that appears unsafe.
But again I'm in Pa. So other states might have different policies. I also have never stopped while driving my personal truck hauling my gooseneck and have never been chased down.
Dozerboy
4,892
470
TX of course
It does depend on the state, but I would pass them up. Unless you go through one of those once with the electric signs and they tell you to exit on it. I have never stopped at one. I was normaly on the heavy side so the boss wanted me to always go around them.
Novak
SQUIRREL TRYN TO GET A NUT
Jun 15, 2015
990
Cloud 9, IDAHO
Fed law is if it is registered over 26k ON THE DOOR THERE SHOULD BE STICKER IF SO
If no sticker, then don’t stop. If you did stop they would wave you through 10/10 times being in a box truck.
26k or higher would require a Class B CDL at a minimum regardless of restrictions just because everyone under the sun does not know how to stop that much weight on a nasty hill grade so therefor you should be licensed and trained and tested on how to do so.....even if you have hydro brakes they still catch on fire just like air brakes
zakkb787
<that’s not me...
Sep 29, 2014
2,340
52
Granite Falls NC
My old boss passed one up when we were towing his bobcat and bucket and some block with his 2500 Chevy. Trooper ran us down and made us come back. Also another trooper stopped us and made us weigh at a gas station. Guess it depends on the mood they’re in.
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
French Creek, West Virginia
I see why if you have a long gooseneck with multiple heavy items and a business name on the truck, they assume you’re over maximum allowable without a dot tag and cdl so they were looking for a big dollar ticket. Never going to happen in a normal truck with just a camper or one item on it.
2,146
Northern California has signs posted at all weigh stations stating no pickups. Doesn't specify commercial or not
The definition of "pickup" changes per DMV when you replace the bed with something other then stock. Tool boxs, flat beds, etc
There is a station on the I80 just past Vacaville that many truckers use to bypass buy taking a side road. The state caught on and now park highway patrol out there to watch for anyone skipping the scales
The way I've always understood it was basically anyone driving a vehicle with DOT stickers on the door needs to stop
zakkb787
<that’s not me...
Sep 29, 2014
2,340
52
Granite Falls NC
It was a flat bed single wheel with a 16 ft hitch trailer. Not anything crazy
