Weekend warrior.... grrrr!
Josh154
1,220
85
Sioux Falls SD
Call mark and see what he suggests. I believe I read where the modded lly and 3794 is the same back half, the 3794 is just a 65mm on compressor side. Look at the dyno graphs on both turbos, they are pretty dam similar.
Troysalm71
286
Bemidji, MN
What does your modded lly charger consist of in the build? I too am now curious as it may be easier to find one of those. Now working on an lml is another story itself. I figure this way maybe it's more cost effective an someone could build it here on the forum. Thanks
Josh154
1,220
85
Sioux Falls SD
My modded charger has the 10 blade high flow turbine, tct compressor wheel, fingers high flow vanes, port and polish with a rebuild kit from Midwest turbo that has the 360 thrust bearing.
