Well to answer your question its new and I was there for 3 hours swapping regulators out that did nothing still had pressure maxed checked the fuse in the ppe harness was good re did the postive and negative still nothing i cooled the damn control box down and it worked so i put it somewhere better to keep it cooler havnt had any issues again they have worked awesome other wise and i know there top notch thats why i bout there kit. also I ran my times on a 2200 pw then threw a 2400pw which dynoed 607, an I have the slip if I have time ill post it and I didn't smoke the lights a rmr Guy kicked the Guy I was racing staging lights also from Idaho's and screwed it up and he beat me NY a truck an he has been running low low 12's there so whatever if you don't believe me whatever Congrats on your passes an your 9.98 in Canada. Also all my 60' times were 1.8-2.0 an still running 12's I had traction issues along with cutting bad reaction times for me so o well such is life and a 12.3-12.4 would be fine at rmr for me no Nos for me maybe water Meth but no Nos ill do twins first
also i had a 12.8-12.5-12.7 and then my 14.16 those were my only 4 passes that night need better tires and spring clamps and ill get my times down mayeb after im back from nd i'll hit the track again
