Water to Air Intercooler
CurtisEmery
Mar 21, 2008
486
Ontario, Canada
I didnt look at my boost on my 11.0 pass and havent ran it turned up since , i figure the twins i have now would put out maybe 65-75 psi depending on how much heat you through at it , but Nathan is right if i go bigger the frozen boost unit probably wont cut it .
I think all of the others parts you get in the kit would make the cost worthwhile. Even if the cooler fails you still have all the other parts IMO...
I think I may try Frozen boosts kit next season on the puller. I make nowhere near the boost you guys with twins do thou, so I figure it should hold up ok.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Update , I am going to try the frozen boost kit , after talking to there tech people they have alot of people using them at over 70 PSI , they just wont warrenty it above that , the metal used for the core itself is 1/8" thick aluminum , I cant imagine that thick of material would balloon out . Plus a certain :dale-simon: bought one and put it under 100 psi artificial load and left town , it was still at 100 psi when he came back :D
Idaho CTD
Junkie
May 28, 2008
179
Idaho
The Spearco air to air's are 1/8" and they balloon like crazy. Obviously the smaller pieces, more welds, etc generally would make the tanks stronger on a water to air though.
Idaho CTD
Junkie
May 28, 2008
179
Idaho
Pressure testing doesn't compare to boosted air running throught it. The heat and on and off boost situation fatigues the joints over time.
TrentNell
Jul 7, 2008
7,543
slc tuah
I definatly agree , If it fails i will have a custom one made by the Company Russ is using .
