So what is picture is just normal wear?
Mine was not eroded as bad, but I think you will be fine.
Should I be looking for a new housing? Truck has 118K on it.
oh before you put the balencer back on pressure test the system, it would suck to find out it leaks when its all back together
use an air compressor and some fittings, fill the system up with air to 12psi.
i found out the hard way only place i could think of it leaking is the metal gasket that connects to the log that goes under the driver side of the engine. all the o-rings should be fine if they were installed correctly
re assemble the themostat housing and get a air gun with the rubber tip and reulate the air to 12psi and fill it up.
usually its something big that is sometimes missed that springs leaks. but if you took your time you really shoudnt have a problem with leaks
