Water Pump leaking?????
catmenace
255
you might want to tig the impeller so thast it doesn't spin off like the new GM water pump I put on. Had to redo it, this time tig welded so that will not happen. They are pressure fit so if you have extra HP you may have a problem.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
get a SoCal Dampner and the next time you have to swap its.....So much easier:D
there is no fix to the problom just bandaids....unless you go electric:( and i dont know how well electric would work on a DD?
Take it to robert mike....he needs to see what a REAL slick lookin dmax looks like:D
stacks04
792
Terryville,Ct
There isn't really any reason to be looking into the pcm for a coolant leak Mike. If they do for some off the cuff reason and they figure it out you've already accepted the worst case scenario so to me its worth a try. They are becoming more common so odds are they stock it and probably will have it done in half day.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Yea I figured that, Ill try a dealer. I wanna be up front with them ya know. I have a stack and no dpf so who knows.The major issue here is it takes at least 2 days of your truck in the shop :confused:
