If you are building a race engine, there is a potentially dangerous problem with our waterpumps. The gear is pressed on the shaft, and on Casper's engine it started to come off and was slipping.
Not sure how often it happens, but I'm hearing I'm not the first. Cheap insurance is to throw a TIG bead around the snout, being careful not to heat soak the entire assy and wrecking the bearing.
