Water Leak under Glove Box
FC5452
301
Eastern PA
Did you verify the drain isn’t plugged, I know you said you checked the 90, but did you check the passage?
If it doesn’t smell like A freeze it could be a widow or cowling seal.
catmenace
255
Do you have a sun roof? Don't know about GMC but I had a new 2018 Ford F350 and had the same issue. There are drain tubes coming from the sunroof and one came off. Caused a major leak inside on the passenger side because the water came down the inside of the pillar.
CarolinaHD
969
NC
Water might be collecting under the windshield cowl trim and draining into the blower motor inlet. Had the same issue on a 08 mustang.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,224
370
At Da Beach
Use an air compressor to blow out drain for condenser, I'd use 10lbs or less, I cleaned mine out with a piece of Monel from a ballyhoo rigg... Lol...
