Wastegate for stock turbo
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
I need a wastegate for when I spray my truck. I'm not sure what size I need or what PSI to have it open. I will be putting it on the passenger side uppipe. Does anybody here sell them?
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
have you tried using the boost and vane tables so they will open when you are spraying?
dmaxfireman
Apr 8, 2007
2,329
CT
ouch, yeah i guess wastegate is gonna have to be the way you go, henry should be able to get them
paint94979
Beer Nazi
Sep 18, 2006
11,715
I told you just in the essence of time go to ATP turbo in hayward man its not even 1 hr away from you
Mike_S
OOPS!
Nov 18, 2009
803
40
Idaho
I think that you will want to vent both up pipes with the wastegate, not just one. unless im misunderstanding your plan, or i am mistaken and your turbo is not a divided scroll.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Trent doesn't want my business.
Anybody else have wastegates?
Anthony it def isnt a matter of not wanting your business , just hasnt been enough hours in the day to do that tune we were going to do , when we talked i figured i would have the time that week but what i had lined up didnt go as planned , my average hours the last 2 weeks ( months really) have been 8 am - 3:00 am with a 3 hour dinner break to see the family and 2 days till 6 am , please dont take it anything against you i didnt get the tune done I really wanted to. If you do end up not finding a gate I have 5 on the shelf .
gmduramax
Shits broke
Jun 12, 2008
4,072
248
Nor cal
what turbo? if it is a divided scroll that will be less than ideal. unloading drive pressure from one bank of cylinders and not the other probably isn't the best idea.
Stock turbo. I don't see why not. It's not like I'm running 0 pressure. I'm still leaving 40psi in the up pipes.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
if you feel the two inlet ports on the hot side of the stock turbo, they converge pretty much right away.
This is what im doing with my new engine, mounting a wastegate on the EGR flange of the up-pipe, and then gating it into the hot-pipe for the twins....that way I can run a big primary and still keep the VVT, without having the restricted hot side of the VVT.
1,866
Smart idea to use the EGR port.
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
fwiw gating only one side works fine, that is how we do all our 6.4 wastegates on basic setups.
Did you end up getting a gate?
