Shane, I've played around a bit with the Syncronic Gate, what are you needing help with?
the way all the wastegates we run are plumbed is you want full boost on the side port that will push the gate open, you run regulated boost to the top port that holds it shut. then dial it it to open when you want it to. Using this method the spring has no effect on gate operation.
The honest best way to do it is on the dyno, my truck went from 959 to over 1k with wastegate adjustments.
let me know if i can answer any other questions.
I am sending you my reply from Synapse from last year when I was trying to figure it all out too.
Are you running both boost from the same source or using full to open and charge boost to regulate?
Sent from my DROID RAZR using Tapatalk 2
