Wanting to switch up
Dozerboy
4,918
498
TX of course
You have a problem somewhere. Even if the injectors are bigger a modded pump doesn't put out enought fuel to to make your setup smoke. Say you have bigger injectors and a 12mm stroker pump. You still shouldn't be smoking at only 850hp. Your setup should make more then 1000hp without tons of smoke.
Someone correct me if I'm wrong...
durawhore
Aug 19, 2014
124
Definitely wil be checking for leaks once its all back together
nmband13
53
Sioux Falls SD
Last year I ran a sxe369/s484 non gated with 0.9 housing on the 369, with 200% injectors and at wot it had a slight haze. You definitely have issues somewhere
