Wagler Heads and Intakes
DaveB
Sep 6, 2009
409
Northeast Indiana
Call Jeremy, he will point you in the right direction. There are several guys running the heads here that have first hand experience of his customer service. There becomes a point with a competition setup warranties do not apply, but he was very good about taking care of everyone. :thumb:
It's not likely to have many guys tell you what they are making HP wise.
T800
Mar 13, 2015
I don't expect to get others HP numbers just trying to figure what advantage if any not afraid to spend the money if it's worth it
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I think you would find quicker spool, lower peak egts, and more power in the upper RPMs. I don;t think the stock heads will ever be able to flow enough to support your power goals. Talk to the source and call Jeremy.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
The heads on my motor are factory LB7 heads that were CNC ported by Wagler with over sized valves and I don't think I could make more than 1300-1400 hp with them. Spend the money now or you will wish you did!
boominator
168
5
MI
You're short on fuel by a lot, and if your worried about spending the money on heads you need to reevaluate what it is realy going to cost to build a 3.0 truck
Sent from my SAMSUNG-SGH-I747 using Tapatalk
doug9940
Ca LLY
Dec 6, 2009
391
56
Corona, Ca.
Perhaps a better question would be to ask how much air they flow. What's the CFM rating on these heads and then compare that to the CFM on the heads you have or the heads you are considering buying. Then you will be comparing apples to apples. HP numbers are dependent on too many other factors to attribute any gains to one particular part.
SmokeShow
6,818
Lawrenceburg, KY
If you're going to compare CFM numbers, you better make sure they were checked the same way. On the same equipment would be the best. ;)
What part of the country are you in? Just out for fun or do you want to be competitive? If you're trying to be serious, the 3.0 class is pretty serious almost anywhere in the U.S. IMO, you'd be wise to bolt a set of these heads to your truck.
If you're into learning, build your setup with OE-based heads, strap it on a dyno and let 'r rip. Tear it down, strap on the waglers and redo the dyno tuning sessions and see if your peak and area under the curve increase. I predict they'd both be considerably higher, especially the area under the curve above 5000rpm. :thumb:
quadracer37
Mar 31, 2009
547
northern, IL
That's probably not going to happen with stock head's!.
Yes it can :thumb:
It's an air limited class. Your only going to make so much hp with X amount of air. However finding the correct combination of parts can net gains. Typically cams do nothing but change power curves. High flowing heads and large cams make hp in higher rpm ranges and require engine to spin higher then a smaller cam and lesser flowing heads.
400's are fine for 3.0" class and said hp goals. 1800 is stretching it though for 3" power. All though dynos do vary.
All first hand experience Dyno testing.
I do recommend the edge hot unlock code for all Dyno testing also. :D:roflmao:
T800
Mar 13, 2015
Waglers Heads and Intakes
Hey quad racer 37 do you have any knowledge of Waglers Heads
quadracer37
Mar 31, 2009
547
northern, IL
Yes.
Don't expect people to spill their knowledge of what works and what doesn't. The pulling world is very competitive and customers like ours spend a lot of money testing and trying new things to find what works and what doesn't. And it doesn't get handed out for nothing.
S Phinney
4,008
Quncy, Fl
As cast Brodix heads will flow about the same amount over a stock ported head as a stock ported head does over a stock head. If your wanting to be one if the best then you gotta make wise choices on your parts combination.
PACougar
2,105
41
El Dorado Hills, Ca
Look, if you really want to be competitive you have to go overhead cam heads. All you need to do is retrofit some 4 cylinder VTEC heads and you'll be dominating in no time.
