Set up the v2 to log rpm, main injection mm3, actual vane position, desired boost, and actual boost.
open the log in the efilive scan tool, make a map.
paramater - turbo vane position
column - engine rpm
row - turbo boost pressure
start the column and row labels with a 0, then put in what the desired vane position chart has.
on the bottom row at the top is an X with a line over it, click on it and you will get an adverage of vane position to put into the desired position chart. I would start with a 10 or 15 minute run, try to cover as much as you can - lingering several seconds at each power level (throttle position - rpm/speed will increase and that is good).
Log, average, flash the truck and repeat. You may have 4 or 5 times to dial the desired vane position in for your current desired boost levels. Once you get the vanes where you want them, take the trailer on a longer run - logging all the way. Once all is said and done, if you want to spool the turbo faster, add 5% to the desired vane tables.
