with the completion of my dmax swap and shake down tow. i have noticed that the spool repsonse is slow then the stock IHI Lb7 charger. i would like to change that. question is how.. fuel is the quick answer but with stock 4l80 im basicly maxed out.. a more repsonsive turbo will result in better mpg esspecially when it comes to pulling hills.
cruising rpm with 4.63 gears and 32" tires is 1900-2500 or 55-70mph
one thing i noticed on my shake down tow.. when pulling 7% grade.. truck was floored at 2100rpm and only makeing 10-13psi. above 2400 i can get 20+ easy. either desried boost if off or VVT is off or combo of both
with that said. can i basicly take the VVT table and linear blend them? so the VVT would behave similar to a fixed AR charger.
example since i havent figured out how to screen shots
800rpm collum is stock 80% for basicly all of it.
1800rpm collum is stock 54% for basicly the entire collum.
3000rpm collum is stock 28% for basicly the entire collum
so the idea would be blend L-R 800 to 3000 collums.. granted a fixed non gated AR would have the same VVT% across the entire table.
pros cons?
pros cons?
