video of sled pull.. imptovement opinions?
L0B6Z
Oct 19, 2013
168
oxford ny
I know I'm running low rail pressure and gotten 22lbs of boost, but how can I keep my truck from lifting so much? I lowered it and added 1ton springs.
so any input would be great.. I get low rail above 3800rpms, I'm spinning 4200ish down the track at 20k rail.. Didn't do this till I ported my fitting. Stock fitting is going back in. Buy I want a gd setup and to stop blowing my tires off. I'm running 20lbs in front tires and 30lbs in rear. Truck is sideways down the track
https://www.facebook.com/photo.php?v=486994848102844
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Get your hitch as close to the back of the truck as rules will allow. It gives less leverage to the sled to lift the front of your truck. Here is a picture of mine.
Micheal Tomac
been pulling forever
Aug 12, 2008
273
MI
you need more rear tire pressure, you're losing hitch height with only 30psi in the rear
you also need adjustable stops in the rear
does it always dog track when you pull?
L0B6Z
Oct 19, 2013
168
oxford ny
I'll try more air in the rear tires.. When I'm at 45 I smoke the tires. We are not alot bump stops aswell.. My friends 07lmm barely sags and lifts only about a inch..
L0B6Z
Oct 19, 2013
168
oxford ny
no I wish. Not allowed airbags... I might sneak in bump stops and I'll raise my front with a shim of some sort
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Obvious question is,is his set up any different hitch ,truck model,etc etc , including brand of tire ?
L0B6Z
Oct 19, 2013
168
oxford ny
you want to lower you torsen bars down all the way if you're not hanging weight
I don't have my torsion bolts in right now. Lowered the truck so I didn't have to keep messing with them.
side note- should I crank up the bars any for when I do run wieghts? Will run them next yr where is allowable
L0B6Z
Oct 19, 2013
168
oxford ny
and don't cheat, good grief. If it says no bump stops, then don't run them. Pretty simple concept. :thumb:
well most places don't let you. I ran em once and I hopped bad. I think I'm gonna have them set to 1" of travel and try it. I hopped when it was blocked completley.
L0B6Z
Oct 19, 2013
168
oxford ny
I am also going to order the arsenal kit for my cp3 so I can keep fueling past 3600rpm.
working on a set of front end stops to keep my front end sitting where it does while pulling down the track.(bolts all the way out). I heard this helps keep hitch hieght.
also got some wieghts finally. Airing fronts down to 20lbs and rear to 40lbs. Going.to try lockup box also
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
I'll sell you my lockup box. if interested pm me. Bt lockup, $300
Gmclbz
Jul 8, 2008
1,048
www.upstatedieselperformance.com
Nick, don't waste your $ on an arsenal kit...just my 2 cents....
