just another thought... drivability issues suck!
I had a similiar vibration after i found the first few...:rofl:
Anyway i had another that started after it was warmed up. Turns out the exhaust grows with heat, alot. I found it by using cork 1/8 " gasket mat'l. I placed the gasket mat'l between what i thought could be pinch points drove it around for awhile and went back and checked all the gasket mat'l. Turns out as stuff expanded or grew with heat it was hitting something else!! In other words if the gasket mat'l is penetrated/pinched through, making a hole, you know its hitting by expansion. Process of elimination. If it doesn't wear through but shows flashing and the vibration stops? Thats you source.
Hope this helps hunt it down, look for the basic shit first then start looking for a polka dot Zebra.
Good luck Dude!
