Valves Recession
Dozer1980
Nov 17, 2013
I am brand new to the forum and I have searched for this answer and I have not found a minimum spec for the situation I am currently faced with. I took on the job of a true basket case. I am working on a 2005 C4500. The engine had approximately 72000 miles and it apparently blew a head gasket. Was pushing compression into cooling system. The owner of the truck hired a mechanic to repair this vehicle and he got it all apart and sent heads to an unreliable machine shop in my opinion. The gentleman that was working on the truck got the heads and valve train and covers back on and got sick and was diagnosed with cancer and unfortunately passed away. The owner of the truck was desperately looking for someone that would finish the job. I accepted under the condition I would not stand behind any of the work done prior to me. He agreed and the truck came to me in many boxes. Got the engine and truck all back together and no left over parts. Problem is that I could hear an noise in the top end of the engine and started doing more research and found valves were at .008 approximately and questioned machine shop into how much material was removed not real sure. I am concerned that the valves are not recessed enough and the valves are hitting the pistons. Removed one head and using a straight edge and feeler gauges I am approximately .015 on intake and .025 on exhaust. I think from what aim finding that is to close. Sorry for the long post but I wanted to include all information that is applicable. Pleas help. I am bringing home a depth micrometer tomorrow to get a closer measurement. Thanks
jkholder09
Jan 8, 2012
1,188
Maryland
Take valves out and mill the face.
They are usually just .005" above the head.
I think the spec you want does not exist because the heads are not to be resurfaced.
You could also use grade c head gaskets they are the thickest.
Or you could measure piston potrusion.
If the valves were hitting there should be a mark. Put playdough on top piston and turn it over with head on is another option.
Sent from my SPH-L300 using Tapatalk
Fingers
Village Idiot
1,714
84
White Oak, PA
The valves will be recessed more after a valve job, to be expected. NOT the source in of itself. If anything, it will create more clearance for the valves. Use clay or poly or whatever and check the valve clearances then get back to us.
jkholder09
Jan 8, 2012
1,188
Maryland
I am not totally sure but I think he was saying that the heads were milled but the valve seats were not touched.
You would know better than me but the only spec I could find was installed height for the valves and valve guide wear.
Dozer1980
Nov 17, 2013
That is correct the head was milled but the valves have not been touched. The guy at the machine shop has no record of what was removed from the head but he is sure he did not do anything to the valves. I have both heads off now and I do not see any marks on the pistons or valves but the head gaskets were installed backwards from side to side. They were felpro gaskets and measure approx. .039-.040 thick
Fingers
Village Idiot
1,714
84
White Oak, PA
So the valves are protruding 0.015" above the head surface? Regardless, the only real way to tell is to actually check the clearance with clay or poly. The stock cam leaves lots of room for clearance, I just don't know how much.
ripmf666
15,123
14
47
Wentzville Mo
Service Information
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do>
2004 Chevrolet Chevy K Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | Engine | Engine Mechanical - 6.6L (LB7) | Specifications | Document ID: 827716 <HR>
Engine Mechanical Specifications
<TABLE border=1 width="95%"><TBODY><TR><TH vAlign=bottom rowSpan=2 align=middle>Application
</TH><TH vAlign=center colSpan=2 align=middle>Specification
</TH></TR><TR><TH vAlign=center align=middle>Metric
</TH><TH vAlign=center align=middle>English
</TH></TR><TR><TD vAlign=top colSpan=3 align=left>General
</TD></TR><TR><TD vAlign=top align=left>
  • Engine Type
</TD><TD vAlign=center colSpan=2 align=middle>90 degree V-8
  • Displacement
</TD><TD vAlign=center align=middle>6.6 Liter
</TD><TD vAlign=center align=middle>402 cu in
</TD></TR><TR><TD>
  • RPO
</TD><TD vAlign=center colSpan=2 align=middle>LB7
</TD></TR><TR><TD>
  • Bore
</TD><TD vAlign=center align=middle>103 mm
</TD><TD vAlign=center align=middle>4.0551 in
</TD></TR><TR><TD>
  • Stroke
</TD><TD vAlign=center align=middle>99 mm
</TD><TD vAlign=center align=middle>3.8976 in
</TD></TR><TR><TD>
  • Compression Ratio
</TD><TD vAlign=center colSpan=2 align=middle>17.5:1
</TD></TR><TR><TD>
  • Engine Compression Test - Minimum
</TD><TD vAlign=center align=middle>2069 KPa
</TD><TD vAlign=center align=middle>300 psi
  • Idle Speed
</TD><TD vAlign=center colSpan=2 align=middle>680 RPM
</TD></TR><TR><TD>
  • Firing Order
</TD><TD vAlign=center colSpan=2 align=middle>1-2-7-8-4-5-6-3
</TD></TR><TR><TD colSpan=3>Block
</TD></TR><TR><TD>
  • Cylinder Bore Diameter - Service Limits
</TD><TD vAlign=center align=middle>103.11 mm
</TD><TD vAlign=center align=middle>4.0594 in
  • Cylinder Bore Diameter - Production Value
</TD><TD vAlign=center align=middle>103.0-103.014 mm
</TD><TD>4.0551-4.0557 in
  • Cylinder Bore Out-of-Round - Production Value
</TD><TD vAlign=center align=middle>0.015 mm
</TD><TD vAlign=center align=middle>0.0006 in
  • Cylinder Bore Taper - Production Value
</TD></TR><TR><TD vAlign=top colSpan=3 align=left>Camshaft
  • Camshaft Bearing Inside Diameter - Service Limit
</TD><TD vAlign=center align=middle>61.07 mm
</TD><TD vAlign=center align=middle>2.4043 in
  • Camshaft Bearing Inside Diameter - Production Value
</TD><TD vAlign=center align=middle>61.00-61.03 mm
</TD><TD vAlign=center align=middle>2.4016-2.4028 in
  • Camshaft End Play - Service Limit
</TD><TD vAlign=center align=middle>0.2 mm
</TD><TD vAlign=center align=middle>0.0079 in
  • Camshaft Journal Diameter - Service Limit
</TD><TD vAlign=center align=middle>60.92 mm
</TD><TD vAlign=center align=middle>2.3984 in
  • Camshaft Journal Diameter - Production Value
</TD><TD vAlign=center align=middle>60.932-60.962 mm
</TD><TD vAlign=center align=middle>2.3990-2.4001 in
  • Camshaft Lobe Lift - Exhuast - Production Value
</TD><TD vAlign=center align=middle>5.907 mm
</TD><TD vAlign=center>0.2326 in
  • Camshaft Lobe Lift - Intake - Production Value
</TD><TD vAlign=center align=middle>7.273 mm
</TD><TD vAlign=center align=middle>0.2863 in
  • Camshaft Runout - Service Limit
</TD><TD vAlign=center align=middle>0.05 mm
</TD><TD vAlign=center align=middle>0.0020 in
</TD></TR><TR><TD colSpan=3>Cooling System
  • Capacity @ Engine RPM
</TD><TD vAlign=center colSpan=2 align=middle>270 L/min @ 3172 RPM
  • Thermostat Full Open Temperature
</TD><TD vAlign=center align=middle>110 degrees C
</TD><TD vAlign=center align=middle>230 degrees F
  • Turbocharger Coolant Bypass Valve
</TD><TD vAlign=center align=middle>60 degrees C
</TD><TD vAlign=center align=middle>140 degrees F
</TD></TR><TR><TD colSpan=3>Connecting Rod
  • Connecting Rod Bearing Clearance - Service Limit
</TD><TD vAlign=center align=middle>0.10 mm
</TD><TD vAlign=center align=middle>0.0039 in
  • Connecting Rod Bearing Clearance - Production Value
</TD><TD vAlign=center align=middle>0.036-0.077 mm
</TD><TD vAlign=center align=middle>0.0014-0.0030 in
  • Connecting Rod Bore Diameter - Bearing End - Production Value
</TD><TD vAlign=center align=middle>62.958-62.979 mm
</TD><TD vAlign=center align=middle>2.4789-2.4795 in
  • Connecting Rod Bore Diameter - Pin End - Service Limit
</TD><TD vAlign=center align=middle>34.53 mm
</TD><TD vAlign=center align=middle>1.3594 in
  • Connecting Rod Bore Diameter - Pin End - Production Value
</TD><TD vAlign=center align=middle>34.512-34.522 mm
</TD><TD vAlign=center align=middle>1.3587-1.3591 in
  • Connecting Rod Length
</TD><TD vAlign=center align=middle>163.0 mm
</TD><TD vAlign=center align=middle>6.42 in
  • Connecting Rod Side Clearance - Service Limit
</TD><TD vAlign=center align=middle>0.54 mm
</TD><TD vAlign=center align=middle>0.0213 in
</TD></TR><TR><TD>
  • Connecting Rod Side Clearance - Production Value
</TD><TD vAlign=center align=middle>0.31-0.49 mm
</TD><TD vAlign=center align=middle>0.0122-0.0193 in
</TD></TR><TR><TD vAlign=top colSpan=3 align=left>Crankshaft
  • Connecting Rod Journal Diameter - Service Limit
</TD><TD vAlign=center align=middle>62.88 mm
</TD><TD vAlign=center align=middle>2.4756 in
  • Connecting Rod Journal Diameter - Production Value
</TD><TD vAlign=center align=middle>62.902-62.922 mm
</TD><TD vAlign=center align=middle>2.4764-2.4772 in
  • Crankshaft End Play - Service Limit
  • Crankshaft End Play - Production Value
</TD><TD vAlign=center align=middle>0.04-0.205 mm
</TD><TD vAlign=center align=middle>0.0016-0.0081 in
  • Crankshaft Main Bearing Clearance - Service Limit
</TD><TD vAlign=center align=middle>0.014 mm
</TD><TD vAlign=center align=middle>0.0055 in
  • Crankshaft Main Bearing Clearance - Production Value
</TD><TD vAlign=center align=middle>0.037-0.072 mm
</TD><TD vAlign=center align=middle>0.0015-0.0028 in
  • Crankshaft Main Journal Diameter - Service Limit
</TD><TD vAlign=center align=middle>79.89 mm
</TD><TD>3.1453 in
  • Crankshaft Main Journal Diameter - Production Value
</TD><TD vAlign=center align=middle>79.905-79.925 mm
</TD><TD vAlign=center align=middle>3.1459-3.1466 in
  • Crankshaft Runout - Service Limit
</TD><TD vAlign=center align=middle>0.44 mm
</TD><TD vAlign=center align=middle>0.0173 in
  • Crankshaft Runout - Production Value
</TD></TR><TR><TD colSpan=3>Cylinder Head
  • Surface Flatness - Block Deck - Service Limit
  • Surface Flatness - Block Deck - Production Value
</TD><TD vAlign=center align=middle>0.075 mm
</TD><TD vAlign=center align=middle>0.0030 in
  • Surface Flatness - Exhaust Manifold Deck - Production Value
</TD><TD vAlign=center align=middle>0.1 mm
  • Surface Flatness - Intake Manifold Deck - Production Value
</TD></TR><TR><TD colSpan=3>Exhaust Manifold
  • Surface Flatness- Production Value
</TD><TD vAlign=center align=middle>0.3 mm
</TD><TD vAlign=center align=middle>0.0118 in
</TD></TR><TR><TD colSpan=3>Intake Manifold
  • Surface Flatness - Production Value
</TD></TR><TR><TD colSpan=3>Lubrication System
  • Oil Capacity - with Filter
</TD><TD vAlign=center align=middle>10 qt
</TD><TD vAlign=center align=middle>9.5 L
</TD></TR><TR><TD>
  • Oil Capacity - without Filter
</TD><TD vAlign=center align=middle>9.2 qt
</TD><TD vAlign=center align=middle>8.7 L
</TD></TR><TR><TD>
  • Oil Pressure - Minimum- Hot - at idle
</TD><TD vAlign=center align=middle>98 KPa
</TD><TD vAlign=center align=middle>14 psi
</TD></TR><TR><TD>
  • Oil Pressure - Minimum - 1800 RPM
</TD><TD vAlign=center align=middle>294 KPa
</TD><TD vAlign=center align=middle>42 psi
</TD></TR><TR><TD>
  • Oil Relief Valve Opening Pressure
</TD><TD vAlign=center align=middle>441 KPa
</TD><TD vAlign=center align=middle>64 psi
</TD></TR><TR><TD>
  • Piston Cooling Jet Valve Opening Pressure
</TD><TD vAlign=center align=middle>196 KPa
</TD><TD vAlign=center align=middle>29 psi
</TD></TR><TR><TD vAlign=top colSpan=3 align=left>Oil Pump
  • Gear Shaft Outside Diameter - Drive - Service Limit
</TD><TD vAlign=center align=middle>19.86 mm
</TD><TD vAlign=center align=middle>0.7819 in
  • Gear Shaft Outside Diameter - Drive - Production Value
</TD><TD vAlign=center align=middle>19.947-19.960 mm
</TD><TD vAlign=center align=middle>0.7853-0.7858 in
  • Gear Shaft Outside Diameter - Driven - Service Limit
</TD></TR><TR><TD>
  • Gear Shaft Outside Diameter - Driven - Production Value
</TD></TR><TR><TD>
  • Gear Shaft-to-Bushing - Service Limit Clearance
</TD><TD vAlign=center align=middle>0.14 mm
</TD></TR><TR><TD>
  • Gear-to-Cover Clearance - Drive/Driven - Service Limit
</TD><TD vAlign=center align=middle>0.109 mm
</TD><TD vAlign=center align=middle>0.0043 in
</TD></TR><TR><TD>
  • Gear-to-Cover Clearance - Drive/Driven - Production Value
</TD><TD vAlign=center align=middle>0.064-0.109 mm
</TD><TD vAlign=center align=middle>0.0025-0.0043 in
</TD></TR><TR><TD>
  • Gear-to-Housing Clearance - Drive/Driven - Service Limit
</TD><TD vAlign=center align=middle>0.22 mm
</TD><TD vAlign=center align=middle>0.0087 in
</TD></TR><TR><TD>
  • Gear-to-Housing Clearance - Drive/Driven - Production Value
</TD><TD vAlign=center align=middle>0.125-0.221 mm
</TD><TD vAlign=center align=middle>0.0049-0.0087 in
</TD></TR><TR><TD vAlign=top colSpan=3 align=left>Piston Rings
  • Piston Ring End Gap-First Compression Ring - Service Limit
</TD><TD vAlign=center align=middle>1.37 mm
</TD><TD vAlign=center align=middle>0.0539 in
  • Piston Ring End Gap-First Compression Ring - Production Value
</TD><TD vAlign=center align=middle>0.3-0.45 mm
</TD><TD vAlign=center align=middle>0.0118-0.0177 in
  • Piston Ring End Gap-Second Compression Ring - Service Limit
</TD><TD vAlign=center align=middle>1.35 mm
</TD><TD vAlign=center align=middle>0.0531 in
  • Piston Ring End Gap-Second Compression Ring - Production Value
</TD><TD vAlign=center align=middle>0.50-0.65 mm
</TD><TD vAlign=center align=middle>0.0197-0.0256 in
  • Piston Ring End Gap-Oil Control Ring - Service Limit
</TD><TD vAlign=center align=middle>1.20 mm
</TD><TD vAlign=center align=middle>0.0472 in
  • Piston Ring End Gap-Oil Control Ring - Production Value
</TD><TD vAlign=center align=middle>0.15-0.35 mm
</TD><TD vAlign=center align=middle>0.0059-0.0138 in
  • Piston Ring to Groove Clearance-First Compression Ring - Service Limit
</TD><TD vAlign=center align=middle>0.26 mm
</TD><TD vAlign=center align=middle>0.0102 in
  • Piston Ring to Groove Clearance-First Compression Ring - Production Value
</TD><TD vAlign=center align=middle>0.08-0.17 mm
</TD><TD vAlign=center align=middle>0.0030-0.0067 in
  • Piston Ring to Groove Clearance-Second Compression Ring - Service Limit
  • Piston Ring to Groove Clearance-Second Compression Ring - Production Value
</TD><TD vAlign=center align=middle>0.01-0.03 mm
</TD><TD vAlign=center align=middle>0.0004-0.0012 in
  • Piston Ring to Groove Clearance-Oil Control Ring - Service Limit
</TD><TD vAlign=center align=middle>0.12 mm
</TD><TD vAlign=center align=middle>0.0047 in
  • Piston Ring to Groove Clearance-Oil Control Ring - Production Value
</TD></TR><TR><TD vAlign=top colSpan=3 align=left>Pistons and Pins
  • Piston-Piston Diameter
</TD><TD vAlign=center align=middle>102.948-102.960 mm
</TD><TD>4.0531-4.0535 in
  • Piston-Piston Pin Bore Diameter
</TD><TD vAlign=center align=middle>34.504-34.512 mm
</TD><TD>1.3584-1.3587 in
  • Pin-Piston Pin Clearance to Piston Pin Bore - Service Limit
</TD><TD vAlign=center align=middle>0.017 mm
</TD><TD vAlign=center align=middle>0.0007 in
  • Pin-Piston Pin Clearance to Piston Pin Bore - Production Value
</TD><TD vAlign=center align=middle>0.004-0.017 mm
</TD><TD vAlign=center align=middle>0.0002-0.0007 in
  • Pin-Piston Pin Diameter - Service Limit
</TD><TD vAlign=center align=middle>34.45 mm
</TD><TD vAlign=center align=middle>1.3563 in
  • Pin-Piston Pin Diameter - Production Value
</TD><TD vAlign=center align=middle>34.495-34.5 mm
</TD><TD vAlign=center align=middle>1.3581-1.3583 in
</TD></TR><TR><TD colSpan=3>Starter
  • Rated Output
</TD><TD vAlign=center colSpan=2 align=middle>3.5 KW
</TD></TR><TR><TD colSpan=3>Turbocharger
  • Axial Play
</TD><TD vAlign=center align=middle>0.11 mm
  • Radial Play
</TD><TD vAlign=center align=middle>0.20 mm
</TD></TR><TR><TD colSpan=3>Valve System
  • Valves-Valve Face Angle - Production Value
</TD><TD vAlign=center colSpan=2 align=middle>45 degrees
  • Valves-Valve Face Runout
</TD><TD vAlign=center align=middle>--
  • Valves-Valve Face Width - Service Limit
</TD><TD vAlign=center align=middle>2.5 mm
</TD><TD vAlign=center align=middle>0.0984 in
  • Valves-Valve Face Width - Production Value
</TD><TD vAlign=center align=middle>2.1 mm
</TD><TD vAlign=center align=middle>0.0827 in
  • Valves-Valve Head Diameter - Exhaust
</TD><TD vAlign=center align=middle>31.0 mm
</TD><TD vAlign=center align=middle>1.22 in
  • Valves-Valve Head Diameter - Intake
</TD><TD vAlign=center align=middle>33.0 mm
</TD><TD vAlign=center align=middle>1.30 in
  • Valves-Valve Seat Angle
  • Valves-Valve Stem Diameter
</TD><TD vAlign=center align=middle>7.0 mm
</TD><TD vAlign=center align=middle>0.28 in
  • Valves-Valve Stem Oil Seal Installed Height
</TD><TD vAlign=center align=middle>6.05 mm
</TD><TD vAlign=center align=middle>0.2382 in
  • Valves-Valve Stem-to-Guide Clearance - Service Limit
  • Valves-Valve Stem-to-Guide Clearance - Exhaust - Production Value
</TD><TD vAlign=center align=middle>0.038-0.071 mm
  • Valves-Valve Stem-to-Guide Clearance - Intake - Production Value
</TD><TD vAlign=center align=middle>0.030-0.063 mm
</TD><TD vAlign=center align=middle>0.0012-0.0025 in
</TD></TR><TR><TD>
  • Valve Lifters/Push Rods-Push Rod Straightness
</TD><TD vAlign=center align=middle>0.8 mm
</TD><TD vAlign=center align=middle>0.0315 in
  • Rocker Arms-Valve Rocker Arm Bore Diameter
</TD><TD vAlign=center align=middle>22.010-22.035 mm
</TD><TD vAlign=center align=middle>0.8665-0.8675 in
  • Rocker Arms-Valve Rocker Arm Bore-to-Shaft Clearance - Service Limit
  • Rocker Arms-Valve Rocker Arm Bore-to-Shaft Clearance - Production Value
</TD><TD vAlign=center align=middle>0.010-0.056 mm
</TD><TD vAlign=center align=middle>0.0004-0.0022 in
  • Rocker Arms-Valve Rocker Arm Ratio - Exhaust
</TD><TD vAlign=center colSpan=2 align=middle>1.69:1
  • Rocker Arms-Valve Rocker Arm Ratio - Intake
</TD><TD vAlign=center colSpan=2 align=middle>1.36:1
  • Rocker Arms-Valve Rocker Arm Shaft Diameter - Service Limit
</TD><TD vAlign=center align=middle>21.85 mm
</TD><TD vAlign=center align=middle>0.8602 in
  • Rocker Arms-Valve Rocker Arm Shaft Diameter - Production Value
</TD><TD vAlign=center align=middle>21.979-22.000 mm
</TD><TD vAlign=center align=middle>0.8653-0.8661 in
  • Valve Springs-Valve Spring Free Length - Production Value
</TD><TD vAlign=center align=middle>56.6 mm
</TD><TD vAlign=center align=middle>2.2283 in
  • Valve Springs-Valve Spring Installed Height - Production Value
</TD><TD vAlign=center align=middle>41 mm
</TD><TD vAlign=center align=middle>1.6142 in
  • Valve Springs-Valve Spring Load - Exhaust - Service Limit
</TD><TD vAlign=center align=middle>275 N at 41 mm
</TD><TD vAlign=center align=middle>61.8 lb at 1.61 in
  • Valve Springs-Valve Spring load - Exhaust - Production Value
</TD><TD vAlign=center align=middle>315-363 N at 41 mm
</TD><TD vAlign=center align=middle>71-81.6 lb at 1.61 in
  • Valve Springs-Valve Spring Load - Intake - Service Limit
</TD><TD vAlign=center align=middle>306 N at 41 mm
</TD><TD vAlign=center align=middle>68.8 lb at 1.61 in
  • Valve Springs-Valve Spring Load - Intake - Production Value
</TD></TR></TBODY></TABLE>
© 2008 General Motors Corporation. All rights reserved.
</FORM>
ripmf666
15,123
14
47
Wentzville Mo
Service Information
2001 Chevrolet Chevy K Silverado - 4WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Engine | Engine Mechanical - 6.6L | Repair Instructions | Document ID: 1651925 <HR>
Cylinder Head Cleaning and Inspection
Special Tools
<TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>J 9666 Valve Spring Tester</TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>EN-47909 Injector Bore and Sleeve Cleaning Kit</TD></TR></TBODY></TABLE>​
    <LI type=1>Clean the cylinder head of all foreign material. Do not use a motorized wire brush on any gasket sealing surface. <LI type=1>Clean the threaded holes. <LI type=1>Clean the injector bores using EN-47909 . <LI type=1>Inspect the cylinder head for the following:
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>Damage to the gasket surfaces</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>Damage to the threaded bolt holes</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>Cracks in the exhaust ports</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>External cracks in the water chamber</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>Cracks between the valve seats</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>Restrictions in the intake or exhaust passages</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>Restrictions in the cooling system passages</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>Rusted, damaged or leaking core plugs</TD></TR></TBODY></TABLE>​
    <LI type=1>Measure the cylinder head for warpage with a straight edge and a feeler gauge. A cylinder head block deck with warpage in excess of 0.1 mm (0.0039 in) must be replaced.
    <LI type=1>Measure the cylinder head exhaust manifold deck for warpage. A cylinder head exhaust manifold deck with warpage in excess of 0.1 mm (0.0039 in) within a 453 mm (17.83 in) area must be replaced.
    <LI type=1>Measure the cylinder head intake manifold deck for warpage. A cylinder head intake manifold deck with warpage in excess of 0.3 mm (0.011 in) within a 493 mm (19.41 in) area must be replaced.
    <LI type=1>Measure the valve spring tension using J 9666 . Replace the valve spring if the valve spring tension is less than 275 N (61.8 lb) at 41 mm (1.6142 in)
    <LI type=1>Measure the valve spring for squareness. Replace the valve spring if squareness is beyond 2.0 mm (0.0787 in).
    <LI type=1>Measure the valve spring free length. The production free length is 56.6 mm (2.2283 in). <LI type=1>Measure the valve stem to guide clearance.
    <TABLE border=0><TBODY><TR><TD vAlign=top>11.1. </TD><TD vAlign=top>Set a dial indicator to the valve stem measuring point.</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top>11.2. </TD><TD vAlign=top>Move the valve stem from side to side while reading the total movement on the dial indicator. If the measured valve exceeds 0.20 mm (0.0079 in), replace the cylinder head.</TD></TR></TBODY></TABLE>​
    <LI type=1>If the valve stem to guide clearance is over 0.25 mm (0.098 in) for the exhaust valve guides or 0.20 mm (0.0079 in) for the intake valve guides, the cylinder head must be replaced. <LI type=1>Inspect the valves for the following:
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>Bent valve stem</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>Scored valve stem</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>Worn valve key grooves</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>Pitted surfaces</TD></TR></TBODY></TABLE>​
    <LI type=1>Measure the valve margin. The intake valve production margin is 1.2 mm (0.0472 in) and the service limit is 0.88 mm (0.0346 in). The exhaust valve production margin is 1.0 mm (0.0394 in) and the service limit is 0.73 mm (0.0287 in). Replace the valve if the valve margin is below the service limit.
    <LI type=1>Measure the valve depression.
    <TABLE border=0><TBODY><TR><TD vAlign=top>15.1. </TD><TD vAlign=top>Insert a new valve into the cylinder head (1).</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top>15.2. </TD><TD vAlign=top>Use a depth gage or a straight edge to measure the valve depression from the cylinder head gasket surface (2). The intake valve depression is 0.6 mm (0.0236 in) and the service limit is 2.5 mm (0.0984 in). The exhaust valve depression is 0.9 mm (0.0354 in) and the service limit is 2.0 mm (0.0787 in). Recondition the valve seat if the valve depression is above specifications.</TD></TR></TBODY></TABLE>​
  2. Measure the valve contact width.
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>Inspect the valve contact area for roughness or unevenness.</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>The intake valve contact width is 2.1 mm (0.0827 in) and the service limit is 2.5 mm (0.0984 in).</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>The exhaust valve contact width is 2.1 mm (0.0827 in) and the service limit is 2.5 mm (0.0984 in).</TD></TR></TBODY></TABLE>
    <TABLE border=0><TBODY><TR><TD vAlign=top></TD><TD vAlign=top>Recondition the valve seats to bring the contact width into specifications.</TD></TR></TBODY></TABLE>​
© 2009 General Motors Corporation. All rights reserved.
</FORM>
Dozer1980
Nov 17, 2013
I appreciate the help. I am thinking him putting the head gaskets on flipped from side to side is more of the problem thanks awesome forum
jkholder09
Jan 8, 2012
1,188
Maryland
Are rockers or upper valvetrain dry from lack of oil?
Maybe backwards gaskets blocked a passage.
Idk because I never tried flippin gaskets lol
jkholder09
Jan 8, 2012
1,188
Maryland
They have a left and right because of coolant passages
So then that would cause overheating, the op did not mention overheating, but if the heads were dry of coolant yet the coolant was still circulating in the block but not the head would the ect actually read hot?
Could the heads be getting hot enough to make a popping sound?
I say it would be best to have the heads redone at the machine shop and checked due to poor coolant flow.
Dozer1980
Nov 17, 2013
I never let the truck run long enough to let it get hot. Heads are going to a reputable machine shop tomorrow to have them checked
Dozer1980
Nov 17, 2013
I hope I did not let it run long to long I will know more in the next couple days I appreciate all the help.
Dozer1980
Nov 17, 2013
We'll I think we got it figured out. Got the heads to the machine shop and he thought to check for a bad valve guide and found the rearmost valve wouldn't open. Found that valve was bent. Figuring that the head must have been dropped before it was put together by the other mechanic and it landed on the valve stem and it was bent. Thinking the noise came from the good valve opening while the valve bridge acted as a fulcrum from good valve to the bad valve.
