What valve spring compressors do y'all use? I'd like to get one like a cummins style that you can use with the heads on. But I'd settle for a nice heads off compressor. Didn't know which brands or size to look at
This style works well with the heads off. They usually come with a few different styles of feet and the width of the feet are adjustable also.
I use a 24 valve Cummins 4 spring compressor and made an adapter to bolt it in place of the injector. I use it with the head on and the piston at TDC.
Like the injector and valve cover bolt hole? Or did you have to use the rocker bolt too? That could be an idea use flat bar with a stud on it. But I think there 6mm holes for the cover that would sketchy in think with big springs??
I made a plate that bolted in the injector hold down bolt hole and the center valve cover bolt hole on the opposite side of the injector hole that had a fully threaded bolt welded to it.
I bought the tork tech not long ago
From where? I can't seem to find one
