Valley turbo upgrade - compounds - built engine
NevadaLLY
Adam B
Feb 24, 2019
332
Reno, NV
The turbine side looks awesome. Noticeably bigger than stock. I’ll get some side by side photos at the shop later this week.
Reactions: Dm23
Josh154
1,220
85
Sioux Falls SD
Nice! They have some wicked whistle even in compound setup :) I love mine. Get that turbine whistle cruising and taking off but it’s not obnoxiously loud like a single. Then the compound starts coming on and it’s just all the badass sounds!
Reactions: NevadaLLY
Josh154
1,220
85
Sioux Falls SD
Great! Didn’t have any issues. Constant 12psi in 5th gear 1850rpms at 65-70mph. Downshift to 4th on some bigger hills see boost go 20-25. The 480 is barely singing in 5th at 1850. I’m running a larger 1.32 housing also. Oh and zero smoke whatsoever!
NevadaLLY
Adam B
Feb 24, 2019
332
Reno, NV
I just spoke to a reputable builder who think's I'm crazy to tow with 100 overs and the turbo I selected. Said that since I didn't port the heads, my drive pressure will be through the roof. Anyone agree/disagree? I had thought I took care of all of the issues you can and that Duramax heads already flow quite well for <800HP?? I've done manifolds, up-pipes, the stage 3 turbo, compound (albeit a tighter 1.15 housing), 4" exhaust all the way back. :unsure:
5,933
he may have missed something. drivepressure was never my issue and my exhaust side flowed less than yours. maybe he was thinking you wanted to tow AT 7-800hp?
monster50iii
338
9
I'm curious why more guys don't install a smaller sized gated fixed vane in the valley? I just put on a 68mm stg2r a few days ago and it's very interesting seeing the difference in drive pressure vs boost at all stages (comparing s300sxe vs 68mm stg2r). The stg2r so far is between 1.5:1 to 2:1 drive pressure almost all the time. I can get real close to 1:1 at lower boost pressures but then things get a bit lazy. The 69sxe I was running ran right near 1:1 until I got around 2500rpms at full power.
These findings would make myself consider doing a fixed vane in the valley with a gated housing. I would think things could be a bit more efficient?
NevadaLLY
Adam B
Feb 24, 2019
332
Reno, NV
I told him at 450-500. Said towing on that setup with 100overs... “woooow”. I was kind of surprised. This shop is well known around the ranch and no stranger to the duramax and its capabilities. Maybe just the individual but it made me question what I’m missing. Are the heads that restrictive. The convo definitely has me putting in a new drive pressure gauge.. I’m just running out of room for gauges :)
rcr1978
790
Spring Creek, NV
I tow with 100's and got no complaints other than my valley turbo is to big so it's more work to clean up the lower rpm low boost areas. Only good thing is drive pressure is usually less than the boost or barely over like 2-4 psi in the higher 34-3600rpms but I have a gated charger.
NevadaLLY
Adam B
Feb 24, 2019
332
Reno, NV
You also have the ported heads as this builder mentioned - - :unsure: Did you notice a drive pressure difference before/after heads? I have the same exhaust housing as your 67 (i think) with the stage 3, 64mm. it has a 76x68 in the GT40 housing.
rcr1978
790
Spring Creek, NV
It's hard to say mine was parked for 3 years with a cracked piston before I decided to build a motor for it. Doubtful they did anything for drive pressure I would imagine.
Josh154
1,220
85
Sioux Falls SD
I’ve been towing 15k 5 hour trips with 200s in my lml with bigger turbos on a 800hp tune stock heads and studs no issues. I’d run it
NevadaLLY
Adam B
Feb 24, 2019
332
Reno, NV
I'm definitely going to run it and provide feedback on my setup. Many of you all on this forum helped me select the components for this build so can't leave out the best part. My gut is this is going to be a very well performing, fun, reliable build which has great towing characteristics balanced with some pep unloaded with the max effort tune (every once and a while :) )
S Phinney
4,008
Quncy, Fl
You are not going to have a problem with this setup unless it is a tune related created issue. It does take drive pressure to spool a turbo. Getting it in a acceptable place is where the tuning comes in. Don’t worry much about the turbo selection.
NevadaLLY
Adam B
Feb 24, 2019
332
Reno, NV
Truck seems to run great - still in break in mode but power feels awesome. EGT’s on a 75% throttle wouldn’t go over 1025. Seems pretty good to me!
Josh154
1,220
85
Sioux Falls SD
Sweeet! Post some videos. I did a launch with mine finally the other day and got a good video of it. How big of tune you running?
