upgrades while I install a built tranny and torque converter
Teamvi
Oct 26, 2011
333
Anything that I should upgrade while I swap out my old tranny for a built one I got and a 1058 torque converter? Should I upgrade lines? Motor mounts? any braces? tranny mounts? bolts? also what kind of tranny fluid do you recommend?
thanks
Teamvi
Oct 26, 2011
333
truck is a 2005 lly with normal bolt ons and tuner, will be upgrading from a ats tuner to a efi in the near future. is the stock flexplate ok?
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Anything that I should upgrade while I swap out my old tranny for a built one I got and a 1058 torque converter? Should I upgrade lines? Motor mounts? any braces? tranny mounts? bolts? A:yes you should also what kind of tranny fluid do you recommend? A:alot of times, different builders call for different fluids
thanks
What other mods do you have? Maybe a down pipe, or turbo....lol
Lol
what modz?....all of the above!
Hahaha
Teamvi
Oct 26, 2011
333
Got exhaust, intake, tuner, lift pump, race plug, drilled driver side fuel rail fitting, egr delete, etc. goin to possibly go bigger turbo or twins in the future.
andy-stevenson
Jul 7, 2013
838
Even if you don't do the turbo now or up pipes now. It'd probably be worthwhile to break the bolts loose and pull them and antiseize them. Might save you a headache in the future if you decide to swap the turbo.
Teamvi
Oct 26, 2011
333
Ok, should i upgrade to a bd flexplate while i am in there or is stock fine if its not cracked, truck has 218k on it, also gonna see if i got any seals leaking
15,681
233
I would go with a SoCal flex plate. It is the best one out there.
Teamvi
Oct 26, 2011
333
How durable is the stock flexplate? Read where some have broke them with little power and some with alot, i m probably not goin over 600 hp for awhile, on stock bottom end
15,681
233
My question was about the mag pan.
Awenta
4,090
CT
Spend that money on a cooler or lines that don't leak
