LB7: Upgraded injector fuel return lines
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,780
Des Moines, Iowa
Currently I am pulling mine valve covers apart to replace a injector on the passenger side, along with the valve cover gasket on the driver side and decided to do a retorque then lash the valves. Most of the injector return bolts are stripping out and I had to use channel lock to get them off. Do I just replace the return lines with new ones or does someone have a better solution that is reuseable? I would like to make it so that I don't have to pull the whole line loose to get one injector out. Anyone have suggestions?
Bdsankey
4,165
1,274
Larsen, Wisconsin
As far as I know you will not get around the hard return rail on the LB7.
That being said, Merchant Automotive makes a "HD" return line bolt that doesn't strip out like factory. See link below. They are cheaper at other places but gives you the PN and the concept.
https://www.merchant-automotive.com/10491-MA-Heavy-Duty-Injector-Return-Line-Bolts.aspx
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,780
Des Moines, Iowa
I guess I will give those bolts a try, I also order some ARP bolt 12 points bolts for the valve cover. I am getting tired of GMs using crappy grade hardware, I don't think they intended them for anything more than a one time uses.
Bdsankey
4,165
1,274
Larsen, Wisconsin
Solid plan, I personally always just replace them with standard stainless hardware from my local hardware store to never have this problem again.
From what I can tell the Merchant return line bolts are MUCH improved over factory.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
GMs harware is just fine as long as its not over tightened. With the sealant and rubber gasket it is pretty forgiving. The person who did injectors last can really screw ya.
Bdsankey
4,165
1,274
Larsen, Wisconsin
I more so fight it in terms of corrosion and getting an allen driver into it. I've learned to soak them when penetrant (lightly) and tap the allen socket into each bolt as to not strip them then they are fine.
3,727
296
I have started using the Merchant bolts any time I have to touch the injectors, and have never had one strip out. I always strip out at least one stock bolt it seems.
A trick I found that helps is to cut the crush washer before loosening the return bolt. That long tail that goes between them prevents the washer near the bolt head from turning, which seems to increase the torque required to break it free. I just go down the line with angle cutters and snip each crush washer right at the thin part of that connecting strip. They aren't reusable either way, and it really does help IMO.
I also replace the valve cover hardware with regular stainless. No more problems with the allen rounding out!
