What size can you go up to, before you have to send them out and get them balanced and flow rated?
Could you just buy some 60 overs and swap them out for stock ?
It's a good idea to have any oversized injector tested/balanced. We test, calibrate, and balance all our injectors here within less than 4%. Let me know if I can help you out or get you pricing.
Just thinking fellas,
You think I should try a rail plug before I go ahead and buy a pump, it'll hold 2800us, once you command for more it dies off to 24-25k psi. It's completely stock fuel system lbz with airdog 165.
if your rail plug was popping open youd be in the 11-13k psi range though until you let off the throttle.
Do the bottle test. Pull the little hoop rubber hose in front of the fprv, put a longer hose on the rail side and plug the return side. Put the long hose in a gal jug and tuck under the hood somewhere. Go drive it hard on the big tune and see if there is any fuel in that jug afterward. If there is, put a plug in or shim the fprv. If there isn’t any, that’s not your issue
