I have the headers and up-pipes myself and saw a 10 PSI drop in drive pressure and 150* drop in peak EGTs back when I had the cheetah and was running high drive pressure on it. I planned to get before and after dyno and track results but blew the stock motor after installing them.
I have also installed the up-pipes alone on a few trucks and the owners loved them. With a 4088 already on the truck for months I installed a set on JonathanCasey19's truck and he says it felt like a whole different turbo. EGTs were down and spool up was faster and smoother, boost was higher at a given RPM than before as well.
IMO the higher the hp and the more air you are flowing the more airflow improvements are going to help and be noticed. On a 260 rwhp stock LB7 you aren't moving enough air to notice restrictions; on an 800+ rwhp truck you are moving alot more air and every air restriction you remove will help - filter, intake, 3" tubing from turbo to motor, intercooler, modded Y-bridge and intake runners, P&P heads, headers, up-pipes, pedistal - it'll all help.
