Twins almost done!!
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
While mine empties into the pan, I wonder if the dipstick tube would drain quick enough? Probably a roller-bearing would have no problems, but I'm not sure about a journal-bearing charger. You could test by running a piece of clear tube (temporary) and watching what happens when the engine is cold (highest pressure).
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
Kinda what I was thinking too........I went and looked at mine after it was mentioned about using the fill spout for an oil drain, definatley not happening for me. I have the turbo so low, there's no way it would flow properly.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
its not that bad at all to tap into the pan , just double check your hole before you drill if you set it to far in the fitting will hit the starter or you wont be able to get your bottom bolt back on for the starter .
Jun 28, 2007
3,259
NE Pa
Dipstick....no...although I did look:D
Fill spout...plenty of flow. There may not be a huge angle but the goal is to not create huge pressure in the turbo as to blow the seals out. I have ran many turbos with the drain almost horizontal with no problem.
SmokeShow
6,818
Lawrenceburg, KY
doesn't amsoil make a cap for the oil fill thats already setup for a return there for their bypass oil filtering systems? Or maybe it's FS2500 that does?
Bako_Dmax
GTO Slayer
Apr 3, 2008
657
Bako
Tapping the pan was pretty easy, like mentioned above take some measurements make and mark exactly where you want it and drill her out.:D
