Just got home from work, going to sleep for 3 hours or so and then see how much ass I can kick on getting the compounds done today. I still need to build the hot pipe, downpipe and tap the oil return fitting. Everything else is done.
Mike do you know the import hood trick on these trucks? Makes working under there so much better.. Take the bolts loose and move the spring back to the back hole, hood stands straight up.
If you already knew then ignore that
I know about it. I've had to open and close my hood 50 times checking clearances so I can't put it in the service mode.
Looks awesome Mike! Looking forward to how it performs
You able to get the gate tied into the hot pipe?
