Twin turbo boost levels at higher elevation
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
It is crazy how the different trucks and combos produce different numbers. Even with triples I barely saw 80psi on boost and when I was twinned with this exact combo I saw 65-68psi iirc.
I just wish everything was cut and dry haha I changed the cam and dropped compression along with more extensive porting and my boost number never moved.
cafryer
May 5, 2011
1,074
Utah
Sounds like you have a boost leak..have you tried putting shop air to it and check for leaks?
