A buddy And I installed a 475 over stock twin setup with 60% nozzles. The truck has plenty of fuel. It will smoke till the turbo really light but will only make 40psi.
I tried opening the vane position from 35 and 1800 across the board. Thinking the small turbo might be choking the larger turbo out. Didn't really help at all with boost.
I don't think it would be a fueling issue. All though after the turbos light and only hits 40psi it is smokeless. Could the boost reference table be limiting fuel or could the larger injector nozzles be spraying more fuel then a limiter table calls for and is limiting me on the top end?
Thanks for any help.
