How much blow by do you have? Buddy just went through this same thing and his filters on the catch cans were soaked and not letting it breath.
In his situation internal pressure was keeping the drains from working properly. That is a possibility.How much blow by do you have? Buddy just went through this same thing and his filters on the catch cans were soaked and not letting it breath.
I do believe this is the case.So much oil I cant get rid of it fast enough then the pressure builds and its going everywhere but where it should.Im going to -12 dump lines and pulling the restictors back out.Pull them from the pan and crank it over with the fuse pulled so it won't start and see how much comes out. It will be much more when running. That will verify that they are getting oil through them as well. It does get frustrating chasing down this kind of problems. The high oil pressure won't push it through the drains. It will push it past the seals because it drain fast enough.
Pvc is connected as if it were factory but because of the lly alt bracket used its braided hose from the v covers to pan,No blow by though,first thing I checked and breathing easy.How is your pcv system setup?
