turbo squeelin?????
nwodiesel
Mar 29, 2014
78
Thunder Bay, Ontario, Canada
Hi I have a 01 lb7 that squeels like a stuck pig when the motor strts to build high boost.....that or as the rpm climb. my alternator bearings are kindy sketchy... but this doesn't sound like a belt squeal. Kinda like a bearing? Any ideas guys. Bout to haul a bigass boat 350 miles. thanx in advance
I suspect the turbo could be at the end of its days. It spools down too fast.... or am I missing something simple here like a boost tube leak
The Neens
BFD
4,596
Monrovia, Ca.
Check the up-pipe bolts at the back of the turbo...Ours got loose after a turbo swap and made the high pitched squeal...
Dirtymaxx03
3,109
X2. I lost an up pipe gasket and 30psi and above my truck would screech like a wounded baby owl.
9,903
149
Exhaust leak. Buddy had the same thing on his 6.7 Cummins. Turned out to be a manifold gasket leak.
