HTT blanket ordered :woott:
HTT blanket shipped. :woott: I'll shoot you tracking here in a minute. Thanks! :thumb:
I had thought of doing one of these last time I had mine apart. Noticable difference in anything on a stock charger truck with stock CP3/ bigger nozzles ?
Honestly, it wasn't really a noticeable change in initial spool up on a VVT truck. (Stock turbo, nozzle) They get quite a bit better in mid-range spool up though. They come up on boost harder/quicker once you're underway, passing gear, etc. Underhood temps are night and day difference. It also dropped 20 degrees off intake charge temps on a 80 degree day blasting around town. From 125 to 105. I ran it without a blanket first so the numbers are a little low if anything. Hope that helps!
Do the blankets hurt anything being used on a daily driver setup?
No issues causing any damage or pre-mature parts death with blankets. Is there something in particular you're concerned about?
Was more curious than anything. Always thought they were more for competition use.
