So I have an lly that I’m going to put rods and pistons in and I’m planning on running a stock vvt with a 66mm front cover and a 10 blade turbine. I am going to compound it as it is going to be a tow/daily drive rig. I was thinking a borgwarner s400 80/97/1.15 as the atmosphere. Would this be the proper atmosphere for this setup? Any input is appreciated
I am really hoping this is not a KB Diesel wheel/cover kit. The OEM turbine is not suitable for anything but an OEM compressor in my opinion, it doesn't have enough turbine flow to make use of a larger compressor.
What elevation do you live/drive at? How heavy are you towing? Do you have any ET/HP goals or just want a fun truck? What else is done to the truck (your signature isn't filled out so we have no clue what's done trans/injector/engine wise beyond what you listed)?
Personally I would run a 63.5-64mm in the valley (pick your flavor, we prefer JZ MFG/Fleece/RDS) and a S480/96/1.32 over top of it if you want to play or a 1.15 if it strictly will be a daily/tow rig. I have done many 63.5-64mm VGT and S480/96/1.32 setups with good tuning and been extremely happy with them as have my customers. This is a great setup for 750-800whp fairly efficiently and still drives damn near like OEM with some fuel upgrades (~100% and a 10mm or 12mm).
I would be more than happy to help set you up with a quality set of chargers if needed/desired or feel free to message me with any questions.
