Thanks guys. I ended up using a universal 3/8" adapter and a couple different extensions and topped off with a 1/2" to 3/8" adapter and a 1/2" breaker . HOLY $H1* that sucked getting the turbo out of the valley. I ended up screwing up the Oil feed line and put a little dent in the bottom of the oil return. I'm pretty sure I also jacked up my A/C lines as it gave a few good hisses when I was pulling the turbo out. In reflect, I probably should have evac'd the A/C lines and disconnected them along with the coolant line that crosses over in the area. I was just trying to take as little out as possible.
