LMM: Turbo Poll
Which would you choose?
  • Total voters
    112
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
How long did you run the cheetah? Couldn't you have just twinned off it?
I don't think the Cheeta flows much more then stock but I could be wrong. Also the top turbo I'm going to run needs alot something a little bigger then the Cheeta. I'd talk to trent and buy what will go with the twins. Everything is so expensive why buy things twice.
bml2200
256
IL
I like the response and power of my 71.5 Cheetah and depending on the dyno I'm at or well above the 650 hp mark. But kinda wished I went with twins like JD Dave said.
ZeroGravity58
1,401
51
Maryland
We installed a II stroker pump, ats manifolds and up pipes 60% over injectors and a 2.6 class legal Cheetah 68mm and made 685hp on an 08 LMM just about 2 months or so ago.
But all the chargers you have listed a great choices.
How is the ATS system? i was thinking of trying something diffrent and maybe do up pipes or up pipes/headers. I have a gasket leaking at the pedistal so i have to pull the up pipes anyways. What kind of gains you see?
boostnsubaru
Jan 14, 2010
41
You can twin off of the cheetah , but it wont work near as well as the S300 , the turbine side of the VVT's even modded wont flow near what a waste gated charger will .
Thanks for the heads up on that! Does that included tw 4094vvt as well?
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
Dont get caught up in hp numbers. A dyno tune is just that, to get numbers. Check around see what people run for times, see who is winning pulls and not in a work stock class with modded stockers, and then decide from there. I'd just go with twins or the htt from the begining but thats my opinion.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
An HTT has a 71mm ( exducer ) turbine wheel and 2 1" waste gate ports on top of that , that's a lot of turbine flow and to be honest you need it in a twin setup if you want it to work properly , it can work with less but ..............
I am not saying the other chargers are bad , but the HTT is far better suited to twin off of .
TrentNell
Jul 7, 2008
7,543
slc tuah
Trent when are you going to build twins for the LMM?
Not for a bit , unless i get a truck close that will bring it out to have a set built , Call Nathan @ MPI he will take good care of you , if its a bit down the road i am sure i will have something available .
boostnsubaru
Jan 14, 2010
41
I have some pics of it when it was lifted but not any with it lowered.. I went with the rockstars and wish i would have picked novakanes. Now it just looks like MMLMM's truck lol
