Just the edge insight hooked up to the obd2 port, truck has intake, exhaust, ats tuner on power level 4 of 10( similar to ppe tuner) fass 150 lift pump, ppe race valve
Without the add on pressure sensor the you won't get an accurate reading. The stock sensor maxes out. I can look at the stock sensor on my insight and it shows 24 psi but if I look at the extra pressure sensor that you add to the insight I see up to 58 psi.
Just be sure you have a spot to put it. There's no spot from the factory to add a boost gauge, unless you've got an aftermarket y-bridge/egr delete/boost tubes you probably will have to tap a spot to put the sensor in.
