turbine housing
02maxhd
Mar 25, 2010
13
Jerseyville Il
Trying to get a handle on all the different options when it comes to turbo sizing. Right now have an airwerks s366on the truck, its a 66/73/.88. Was wondering what advantage there would be to replacing the .88 open turbine housing with a .91 divided. Right now have insane egts, peg a 1600 degree gauge with a 30 to 80 mph wide open run. Would this help with egt, move power up in the rpm ect.
ecc_33
Junior Member
Aug 10, 2006
1,925
39
Amanda, Ohio
yep what bullfrog said, get a bigger turbo or add some water injection. Or pull some pw out of the tune...noone likes to do that though :D
ecc_33
Junior Member
Aug 10, 2006
1,925
39
Amanda, Ohio
i would say you could go bigger frame. like a s465 or 464. They drive well on the street and you can still tow at a respectable level. You shouldn't try and pull semi trailers down the road but i would say 10,000lbs should be ok with a proper tune.
02maxhd
Mar 25, 2010
13
Jerseyville Il
Running a race tune from pat, egt's are fine daily driving,just gets hot quick at wide open. Not really comfortable with making any large tuning changes, still trying to get a handle on how everything works.
