Turbine housing size difference in compounds
13,751
821
Sorry, I made a mistake yesterday when I typed that. The S300 has a 70 mm turbine, not a 71.
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
Josh nailed it, I can't keep up with the turbo specs.
The 1.10 on the 480 was a great addition. Felt like it actually pulled harder through the entire rpm curve. Shifts were at 3600rpm.
Can't wait to see what the little truck does with this setup!! gonna hit like a ton of bricks out of the hole!! :angel:
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Hi Russ-
That's awesome to hear, I'm happy for you man!
It's always rewarding to dial in your set up.
Russ/Josh-
Now, do you guys think the race cover makes/made the difference on the set? Or would a standard housing be equally as effective?
And how similar are the specs of your S300 to Danville's stg2 3794va?
I'm thinking that I really want to run a twin set up on this next round and so I'm trying to figure out what might be he best set up for my immediate AND long term goals...
I'm pretty set on sticking with the VGT's simply for the simplicity of having a drop in secondary (for now at least) if for no other reason cost
Thanks for the input
:hug:
