While we are talking about lope tunes, I've been fighting a lope on my built motor. Only does it when the coolant is in the 60-120*F range. Above and below that, no lope.
It is a really slow lope. Idles at ~690 RPM for 1 second, then slowly down to ~660 over about a second, stays there for a second, then slowly back up, etc. Once it gets to 140*F or higher, no more lope. Below 40* (down to -12 at least), no lope. It only does it in park/neutral. Stick it in gear, and it does one more cycle, then idles perfect.
The truck would hot idle with the main fuel rate around 5mm3, so I tweaked the pulse tables so it was idling about 10 mm3 (17 with A/C on). If anything, it made it worse when warming up. I've tried playing with the pilot quantity vs. coolant table, but nothing seems to make it better.
Any of you guys run into this, and have any ideas how to get rid of it? Might as well derail this thread :spit:
Edit: relevant motor specs
+100% Exergy injectors
Exergy 12mm stroker, stock LBZ reg (desired and actual rail are perfect at idle)
Comp Cams biggest stupidest cam (starting to regret this)
Race cast 16.5:1 pistons, .020 over
SoCal stage 1 heads
