I know I'm almost perfect with my B1010 tuning. I took your advice and used most of the LBZ units minus a few and seems to work pretty well. Have no surge or lope anymore but occasionally when I go to start it it fires, then almost dies, then fires and idles smooth. I need to log some more but its close.
Tom whats your timing at when your just cruising? My stock tune ran about 2º and commanded about 29mm3 doing 65 on the interstate. I now have the timing up to about 8-9º and noticed now I only need to command about 18-20mm3 at the same speed. Even the idiot gauge went up 0.5mpg. Lowered pilot pulse a bit but I'm still running stock pulse and pressure tables. I'm probably gonna raise it up a bit more here if work slows down and see what it'll do.
Any timing I add I always subtract from the coolant multiplier table so the truck is still as stock as it can be when its first started in the freezing morning. Once I find a good medium for timing I'm gonna play with pressure some more.
Now if only I could keep my foot out of it
And thanks Dave and everyone else informing me on the cp3. Good info to know.
