LLY: Tuning an exergy sportsman
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Selling my regular cab this weekend, buyer is going to install an exergy sportsman pump before he even drives it along with a full egr delete (not worried about tuning that) since the trans will be out and it'll just be easier to do everything at once.
I have the truck tuned already and need to modify the tables for the exergy pump. I've searched around and havnt been able to find any info on what exactly I need to change.
If someone could point me in the right direction I'd appreciate it. Truck will be about 5 hours from me when the pump gets installed so I'd like it to be right for him.
Thanks guys!
PACougar
2,105
41
El Dorado Hills, Ca
I'm not sure why you'd have to change any tuning for a sportsman pump. It just flows more fuel up to a higher rpm. Unless you're running a pump with a different regulator than the stock engine code.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Has lbz regulator, sorry should have mentioned that
