If my data logs record something other than what is requested in the tune (like having 774 requested torque logged when asking for 1410, or timing 10* or more less then what is requested at that rpm and mm3) What does that mean?? Bad ecm??
Is the truck acting weird also?? I had the similar problem but it was a bug in my scan tool 7.5 version. Unistalled it and then installed it again and it worked ever since. My not be your problem though
Well all my saved log files I had I just emailed them to myself just in case. Im not to good with a computer to begin with. But when I re-installed it all my data was still saved. But if your truck is acting weird I wouldn't think it'd be the same problem I had. Its gotta be something as kory said something limiting you.when you did that did it mess up anything else? like the saved logged data on my computer? I dont wanna reinstall it then find out I lost alot of info, or have to update my blackoboot again or something annoying like that
