Is ATI preferred over Fluidampr?
bigmackmiller Active member Nov 30, 2008 1,046 2 38 Kokomo, IN Nov 18, 2018 #21 Is ATI preferred over Fluidampr?
B Blackmax123 Member Aug 2, 2014 683 1 18 central Pennsylvania Nov 18, 2018 #22 Confused me a little as well. Wagler advertises them as unbalanced in the description. So I took a chance and just pulled the trigger on one. So far it's worked out well.
Bdsankey Vendor Vendor/Sponsor Feb 1, 2018 4,152 1,262 113 Larsen, Wisconsin Nov 20, 2018 #23 bigmackmiller said: Is ATI preferred over Fluidampr? Click to expand... Depends on who you talk to. I personally am running a Fluidampr on my built motor.
Ne-max I like turtles Nov 15, 2011 3,361 64 48 Lincoln, Ne Nov 20, 2018 #24 bigmackmiller said: Is ATI preferred over Fluidampr? Click to expand... Can't go wrong either way. After doing some research I would not do a callies unless you are having it balanced.
Bdsankey Vendor Vendor/Sponsor Feb 1, 2018 4,152 1,262 113 Larsen, Wisconsin Nov 20, 2018 #25 Ne-max said: Can't go wrong either way. After doing some research I would not do a callies unless you are having it balanced. Click to expand... Do some people think you can slap a crank in a motor without balancing the rotating assembly?
Ne-max I like turtles Nov 15, 2011 3,361 64 48 Lincoln, Ne Nov 20, 2018 #26 Bdsankey said: Do some people think you can slap a crank in a motor without balancing the rotating assembly? Click to expand... People do it all the time. Will the throw a new flex plate and damper on and send it. Especially on a stock shortblock.
