Hey Guys,
My brother ROBSDMAX posted up for me previously to help me try and diagnose the problem, and I am still very confused and the truck has now finally quit on me. I'm totally stumped and I'm hoping someone can help me diagnose my issue.
Truck Background. 2005 LLY Duramax, 330,000KMS, HSP Intercooler Pipes, Stock Turbo, Stock Injectors, Head Studs, EFI by PPEI. If you need any other information please just ask.
February 2015 I did my head gaskets, engine out of truck, head studs and grade C gaskets, the usual repairs for a head gasket repair, as well as the Modded Water Pump and Loctite on my Oil Pump Nut. Balance Rates good, truck running awesome.
First problem was blowing an Injector Return Line off Cylinder #6. Reinstalled the line and the clip and never blew it off again. Checked my Balance rates, all good.
Drove another 2-3 months, then truck started developing an annoying vibration at idle in both Park and in Gear. Truck would shake enough to rattle my keys together and move water back and forth in my water bottle. Checked Balance rates, Cylinder 6 was +12, Cylinder 7 and 8 both -7.
Decided to replace the Injector in Cylinder 6 as I thought that was the cure. Ordered OEM Reman from GM dealer, and installed myself. Balance rates stayed the same and made no difference in Balance Rates. On the way home from my shop replacing the Injector, the return line blew off Injector #8. Reinstalled and has been fine since then.
Took my truck to my local GM Dealership, Service Manager is a good friend and looked after me as best he could. Did as many tests as he could and didn't find anything wrong beyond the obviously poor balance rates. Checked compression. Cylinders were +/- 80PSI, but were all above 350PSI. Seemed out of specification somewhat, but wasn't too worried. Left GM Dealer, hooked trailer up to tow my sled pulling truck up north.
Truck started idling funny at the lights with the trailer on. Slight Surge, and almost dying off. Pull in the driveway at the truck pull, truck shuts off dead. Checked the Primer Cap, lots of pressure in the Primer, lots of Rail Pressure on Edge. Sit for 30 Seconds, try starting the truck, started and ran another 45 seconds to get me into the fair and then quit again.
Balance Rates still the same, 4 Very Good, 3 @ +/- 5 or 6, and 1 @ + 10-12
Checked the codes on my CTS. 8 Glow Plug Codes and 1 U0105, which I have called and confirmed with my dealership was caused during the Compression Test they did and they forgot to clear the codes. Checked all wiring and all fuses, and Ice Picked all the Injector Connectors. No start.
Truck is now at home and refuses to start. Need to check my codes with my brother's V2 to see if there is any codes that the CTS isn't reading. My question for you guys is, what do you think is wrong and more importantly, will P0336 be read by the CTS?
I have read loads of threads, and have read the thread titled P0336 by Schwinn68, and am almost certain by the likeness of our symptoms that my Reluctor Wheel has come off. Seems deadly close to the symptoms I had. But don't want to tear my front cover off until I hear your opinions.
Thanks in advance guys
